Why does this fillet fail.
It works OK if I remove the draft angle on the faces the rib is joined to. File's attached.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
Solved by wilkhui. Go to Solution.
I can get what I want if I cut the body in half, fillet then combine but it seems like it should just work.
Mark
Mark Hughes
I made some changes - but I don't like one end.
It would be nice if Fusion had a Full Round Fillet like Inventor and SolidWorks.
I might add a bit of draft to the rib as well.
It's part of a bigger design and the split line will be parallel with the rib so no need for draft on the rib. This is one of those where machining the electrode with a 4mm ball nose will give the fillet but I need the model to show the customer.
Mark
Mark Hughes
Hey Mark - there's an extremely tiny sliver created when the combine is done at one end of the rib, if you extend the 'nose' of Body3 a little bit to avoid this interference then the fillet should work as expected.
Hope this helps!
Indy
