Help, help, help! I wonder if anyone could help me out. I'm working on a project (furniture) in fusion 360 with a future plan to export it to Revit. So far I have tried to assign materials in Fusion and export it to Revit. Materials are missing in Revit. Does anyone know how to preserve assigned materials when exported to Revit. Thanks. 🙂
Solved by Karambaki. Go to Solution.
Unfortunately, I don't think this compatible. Fusion 360 has different material libraries compared to Revit 😞
Hi Sandra,
You cannot preserve the same materials, but you can re-assign them inside Revit, (Basically you can find many of them a-like, as Autodesk uses the same textures among it's products, maybe with different properties, but eventually the same texture)
Now
Export it as a .sat file
Revit 2016 or less
Open Revit Family template (Generic Model or Furniture for example)
Insert > Insert CAD, switch to .sat
and get it inside, then explode it, now you can choose each part of the object and assign a parameter with material into it from the properties, and you are done,
For Revit 2017.1 or more
Check this screencast to know how to get it inside, map it and organize it,
https://knowledge.autodesk.com/community/screencast/5dfaae4b-f5a4-42c1-9581-4d5ab5e8a6d8
Good luck 😉
Hello Forum members,
Currently with the release of Autodesk Fusion 360 I'm finding a recurring question ... "Can Fusion export elements to the BIM system?". Currently the system can export only files in the formats: * .sat, * .step, * .stp, * .ides, * .igs or * .f3d (original Fusion).
In this way the process of exporting to an element in * .rfa is subject to export to a generic 3D element without the characteristics of a Revit family.
For this reason, in the official website of ideas and suggestions, I put another topic where it deals directly with this subject. I ask the collaboration of all the members of this Forum to access and vote, allowing to improve the software and making the process of designs, architects and designers working with Fusion 360 easier.
Access:
Prof. Daniel Severino
www.youtube.com/ProfDanielSeverino
