Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Error Message: An unexpected error occurred while downloading and...
3 REPLIES 3
samhh1
983 Views, 3 Replies
I'm getting an error message everytime I try and open one of my designs:
"An unexpected error occurred while downloading and opening a document from A360"
I'm using my laptop in a different place right now, so I'm not sure if it's because of a different internet connection. I've tried restarting my computer and uninstalling and reinstallng 360, but same problem.
3 REPLIES 3
innovatenate
in reply to: samhh1
When you uninstalled, did you use the clean unistall procedure?
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-...
You may also try some of the following suggestions:
Manually Clear the .DAT file:
1. Close Fusion 360
2. Browse to:
Windows:
%LOCALAPPDATA%\Autodesk\Autodesk Fusion 360\<ID> (look for latest modified)
 Mac OS:
~/Library/Application Support/Autodesk/Autodesk Fusion 360
3. Locate and rename the BrowserStorage_login.dat
4. Restart Fusion 360 give Fusion 360 some time as it will need to rebuild the .dat file
5. Retest
Manually Clear Browser Cache:
1. Close Fusion 360.
2. Locate and delete the below directories.
Windows:
%LOCALAPPDATA%\Autodesk\Autodesk fusion 360\{ID}/PLM360Cache
%LOCALAPPDATA%\temp\Autodesk\BrowserCache
Mac OS:
~Library/application support/Autodesk/Autodesk fusion 360/{ID}/PLM360Cache
Open Terminal and enter open $TMPDIR/Autodesk - locate the  BrowserCache directory
3. Open Fusion 360 and re-test.
Note: The directories and contents should be re-created at run time.
I hope this helps. Please let me know if you have any questions.
Nathan Chandler
Principal Specialist
nealchapman
in reply to: samhh1
Found this thread while trying to learn why I'm unable to open any of my projects and instead get a steady stream of "An unexpected error occurred while downloading and opening a document from A360" errors. I AM, however, able to open the Fusion 360 Samples.
I've re-installed and deleted all cache data I was able to find. No dice.
Any/all help would be appreciated.
_neal
nealchapman
in reply to: nealchapman
Solved problem by deleting the Q directory by the method described here:
http://help.autodesk.com/view/fusion360/ENU/?caas=caas%2Fsfdcarticles%2Fsfdcarticles%2FFusion-360-Di...
