Error: Can't open the application 'Autodesk Fushion 360' because it is damaged or incomplete'
It was working 5 minutes ago.
Any ideas on what's going on here??
thank you
Solved by kris_berg. Go to Solution.
Solved by Stuart-H. Go to Solution.
Had the same thing happen here about 30 mins ago
first browser went funny and would not accept commands
closed it down and restated and got the same result as you , note no pop up yo report the issue showed up
my soulution complete wipe and reinstall
system latest 4K iMac
Stuart
We did just release a new version of Fusion 360 from the Mac App Store this morning. Apple controls the update process. I have never seen that happen in an update, but it is possible it was updating the application in the background and something went wrong. I think @Stuart-H is correct, the best solution is to wipe it and re-install.
Thanks Stuart.
I did re-instal and it works now.
Not an ideal fix. but it does work.
Kris
a note mine is not the App Store version , I get mine from your site not the App Store
So I would find it odd that it did a background update
i will will keep my eye on it
at first it seemed like a hard drive going bad but the drive ( fusion drive ) checks out fine , as I said it got flaky then crashed to desktop and would not restart
Hi Stuart,
Thanks for the information. We did push an update for users downloading Fusion 360 from our website last night. Its possible that something went wrong there, although normally when that happens the OS does not detect it and the application will crash. I am sorry you had an issue with one of our automatic updates.
Ugh... I just had a crash and it told me that an update was available and it updated then locked up trying to open up a project. Force killed the and now I get the..
"You can't open the application "Autodesk Fusion 360" because it may be damaged or incomplete.
Now what? This is not he Mac and not form the app store.
Did an uninstall and re-install and got back running. I did not follow all those manual steps in the uninstall, just the main automated one. Those steps look really onerous.
I suspect the servers at autodesk had a glitch when downloading the up date , or a bad update file
i find it interesting that you are not on a Mac ( no problem with that ) so it's not confined to the suggested reason of a Apple App Store update .
glad you have it sorted but I do think the fusion team need to look into this
Non appstore version. Ran into this problem today. Reinstall in progress. Holding back expletives.
Edit: Reinstall, Fusion works fine, no data lost. I will be keeping the Client Downloader on hand for future issues.
Side rant: I can't remember the last time I had to "reinstall" a program to get it to work. Oh wait, yes I do, it was around 2002 back when I was running Windows 98 when I had to reinstall Red Faction because I had installed some mods that were conflicting.
Hi All,
We are looking into this issue. I was able to reproduce it myself. I understand the frustration this issue has caused. I, or another Autodesk employee will reply back to this thread when we have more information.
Thank you,
Hi kevinsworld,
Thanks for reporting that you met fusion 360 installing issue. From the install UI information, you were using the fusion 360 in mac system, right?
Currently, we need some more information to analyze this issue. Would you please help to send me your installing log file? The log file is "$HOME/Library/Logs/autodesk.webdeploy.streamer.log" in mac system. For windows, we could find it as ""C:\Users\{sys account}\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log"". My email is xuebin.li@autodesk.com.
Sorry for inconvenience.
Fred
