I'm trying to gather support for this Idea: http://forums.autodesk.com/t5/ideastation-request-a-feature-or/drawings-symbols-for-burr-tolerance-a...
Reference: http://www.en.technisches-zeichnen.net/technical-drawing/basics-02/edge-informatinos.php
This is something quite needed generally for things made out of metal, in processes like stamping, if I send a drawing of a part I want to be manufactured for which a tool has to be designed and cbuilt I need to specify in which direction I want the burr and how much of it is acceptable, for instance.
I have the same problem.
When cutting sheet metal with a laser, you need to include this spec in order to receive the part like you want it to be.
It would be really great to include it in fusion!
Hope this helps
