I have two parts in my design a collar & shaft. I would like to have a cross section of just the collar. Showing the shaft without the cross section.
Solved by innovatenate. Go to Solution.
Currently the section analysis tool is a "global" analysis. It doesn't currently allow you to specify which bodies or components participate in the analysis.
You could manually work around this issue by using an extrude cut feature to emulate the section view.
You may consider requesting a feature on the Fusion 360 Ideastation to accomodate this workflow.
http://forums.autodesk.com/t5/ideastation-request-a-feature-or/idb-p/125
I hope this helps! Let me know if you have any questions.
Is it still the case where one cannot select individual components/bodies to section?
(There are multiple requests for improvements to SA).
W.
@arwalker324 schrieb:Is it still the case where one cannot select individual components/bodies to section?
YES!
günther
Well it only works on Visible bodies at my place. (3 hidden)
Might help....
