Currently, when I import an SVG file, the scale is always wrong. What I do now is import it, then measure a known dimension and calculate the scale. Then I delete the imported SVG sketch and re-import it with the correct scale. I'd much rather just change the scale of the svg sketch I already imported. Is there a way to do that?
Solved by innovatenate. Go to Solution.
Check out the below screencast and let us know if it helps.
