From about 3 days ago, I've noticed my fusion cannot leave offline mode. Online mode was ok before that. I didn't change network connections and it just went like so.
After that I've tested some different DNS settings, went somewhere else (with different network environments) , changed to my other laptop, but with no luck to come back to online mode. I can access myhub.autodesk.com and this forum through the browser.
Any suggestions or comments are appreciated!
Best,
XJ
Solved by ahsan.autodesk. Go to Solution.
Hi Ahsan,
Thanks for helping! This is the log file.
Best,
XJ
Hi Ahsan,
It seems the "work offline " option is checked and displayed in grey color. I've tried unchecking it , but it
doesn't work.
Best,
XJ
Ok, I was afraid of this. There are two options:
- Go to the Preferences Dialog and reset your options by clicking on "Restore Defaults". Unfortunately, this will mean you'll lose all your preference changes
- Alternatively, take the attached file and paste it into the following folder:
/Users/root1/Library/Application Support/Autodesk/Neutron Platform/Options
Overwrite the file existing there.
The above is the folder for Fusion installed from Mac App Store.
If you'd instead installed from Autodesk.com, the folder would be:
~/Library/Application Support/Autodesk/Neutron Platform/Options
Hope that helps
Thx and regards,
Ahsan
Hi Ahsan,
It finally worked! Second method worked for me.
Firstly I tried restore default settings , but it didn't make the work offline option unchecked.
Then I tried the second one. It unchecked the checkmark but didn't bring the online mode back ( still offline). It turned out
to be my network problem, after switch to 4G network from my phone, online mode was back!
Then I changed back to wifi-network and now I can use fusion online!
Thanks for the help!
Best,
XJ
