Yes I have read remove the constraint but it isn't even an option. Every time I sketch a circle within my component and try and move it the cursor moves the distance specified when I translate but the geometry stays and won't move.
Seems to be the conFUSION norm. You would think moving a circle would be the most basic function?? Guess I will make a solid and extract the edges taking the long way around. What I am always forced to do
Hi infamousmfg8K8W
Thanks for reporting the problem. Could you help make a video for us to understand your problem more clearly? Also it would be appreciated to attach your model here or send it to weining.cao@autodesk.com for us to go on analyze your problem.
Frank
