Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
BUG in Fusion360 simulation - slice plane
2 REPLIES 2
DS_Sweden_2
366 Views, 2 Replies
1. Load model
http://a360.co/2kJJ5QL
2. Go to simulation environment - results
3. Inspect - Create Slice Plane. Pick any surface. Move the slice plane using the arrow handle. click OK.
4. Move the Step slider. All is fine.
5. Edit the Slice Plane. Move  the slice plane using the arrow handle.
6. Fusion 360 shows a log window with rapidly scrolling error messages.
7. When closing the window Fusion 360 crashes
David
2 REPLIES 2
John_Holtz
in reply to: DS_Sweden_2
Hi David (@DS_Sweden_2)
Thank for the detailed steps. I tried to reproduce the problem with two different models that I had, but they worked okay. I have downloaded your model and will run it get results, so I will try the slice plane when it completes.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
John_Holtz
in reply to: John_Holtz
Hi David,
I was able to reproduce the bug using your model. I will report this problem to the developers.
Thanks for reporting this.
John Holtz, P.E.
Autodesk, Inc.
