- Mute
- Permalink
- Report
To reproduce:
- create a sketch
- draw a line
- use sketch offset tool to create an offset copy of the line
- select the new line and convert to a construction line.
- change the value of the dimension created during the offset operation
behavior: New line reverts to a normal non-construction line
expected: construction state of a line should be independent of the offset operation
version 2.0.2139
I'm trying to project existing geometry into my sketch, convert to construction lines, then create normal lines slightly offset for clearance. This seems like a reasonable workflow.. am I missing an easier way?
