Body to Component conversion bug ?
TrippyLighting
Consultant Consultant
TrippyLighting
I this skeletal and parametric design I am encountering errors.
When editing dimensions in the base sketch the conversion from a body to a component seems to appears to loose it's reference but shouldn't.
HughesTooling
I was going to ask if compute all would fix it, downloaded your design and tried and it broke another body to component feature! Also noticed you end up with 2 bodies, I guess the one in the component is a cached copy.
Mark
Mark Hughes
Owner, Hughes Tooling
jeff_strater
You are right, this is a bug.  If the dimension edit had radically changed topology of the sketch, I would have expected to see failures, but in this case, it doesn't seem that is the case.  I'll file this one, and have the team look at it.  Thanks for sharing the model.
Jeff
Jeff Strater
Engineering Director
