Hi guys,
I just got a new mac and it came with a "magic mouse" It has no buttons though and I'm struggling to pan and orbit with it. Do you guys have ways of making it work?
Roger
Solved by TrippyLighting. Go to Solution.
not the answere you may want to hear
i use the new larger track pad and its fine but the down side is they are not cheap good news is they are rechargeable from the lighting connector in a hour 1m min charge give a hour of use
two fingers and rotate ,pinch ect just like the gestures on a Ipad , ( ok you cannot run f360 on a ipad as sutch but the gestures are the same )
Stuart
I have two more suggestions:
1. For CAD and other 3D work use a differnt mouse with a clickable scroll wheel. I've never been able to get the magic mouse to work well with any of the 3D apps I work with (Geomagic Design, Blender, Fusion 360). For 3D work the tactile feedback of a real mouse wheel has distinctive advantages over the magic mouse.
2. there are two apps that will basivally extend the settings on the Mac to allow configuring the magic mouse to have a virtual middle mouse button. the one I remember is magic prefs
3. You could try a 3D Connexion spave navigator.
Strong second to everything TrippyLighting says- while you can get third party apps to “create” a virtual middle mouse button on the magic mouse, I found the MM to be a terrible match for CAD- Imprecise and way too easy to brush or bump and send your drawing into the stratosphere. Personally I found the inexpensive (but corded and weird looking) WowPen mouse a great match for helping my wrist feel better, and having a clickable middle mouse button just works better for CAD. But above all, the basic 3D Connexion space Navigator is one of the best investments (<$100) I’ve made for CAD use.
