Let's say I want to create a lid (which I do). The easiest way would be to have a "revolve on path" or "revolve with rails". But there is no easy way to do this. There is a harder way with surface lofts, then thickenings, then combines, but if there was a "revolve on rails/path" that would solve it.
Here is a simple fusion file showing this:
Any ideas on how to do this easily?
Thanks!
Nick Kloski
Solved by HughesTooling. Go to Solution.
I don't think the sweep tool as currently implemented would to this, but it is imaginable as it has a "stretch" option that can be enabled if you make a sweep with path and rail.
What you're asking for is really that "rail" to be a point and the porofile to stretch beween the path ahd the rail as it is being swept.
I just don't thing that the sweep tool would allow a point as a "rail" equivalent to how you can loft between a profile and a point. Might be worth trying out.
Yeah, I tried sweeping...it works until the profile gets to the first corner bend, but then the profile starts to intersect itself at the center, and the command fails 😞
Ha! Additionally, if you choose to sweep that profile in the file I attached, using the outer line as the path and the inner line as the guide rail, Fusion hangs forever 🙂
Nick Kloski
If you can create 4 cross section one at every 90° loft will work. You can mirror the cross section you have but I think you'll need it in another sketch so it doesn't get selected as one.
Mark
Mark Hughes
Owner, Hughes Tooling
Yep...that is the "harder" way, but one that works. Creating a 1/4 surface loft then mirroring to get half, then mirroring to get full, then thickening. but that takes a long time...and in the file I attached, the top edge has spline-ripples in them, which I loft would not be able to do.
I mean the loft "could" do those ripples, but the profile changes between the long and short sides (because the rail on the two sides would be different, and it would not be what I am envisioning a "revolve on path with scaling" to produce.
Nick Kloski
I changed your rectangles to squares just to see if it would work and in the patch workspace I can get a surface like this.
Don't know if you could copy your sketch 90° the use a non uniform scale to resize. I've attached the file in case it might be of some use.
Mark
Edit. Just looked and there's no non uniform scale option in the sketch workspace so that's a dead end.
Mark Hughes
Thanks for trying! Surprisingly, the sweep works without using a rail (just a profile and path) but creates a super-weird result:
Hence the request to see if there is a "revolve with guide rails" function.
Nick Kloski
I think there's a request on the ideastation for rail revolve. For now how about the attached file.
I managed to make it work as 2 halves, i needed to make a new sketch with just half of the rectangular base profile.
Mark
Mark Hughes
Aha! That works...great solution! You mad mirrored the quarter-sketch-profile, and then lofted one side to the other side, using the outer bottom edge/line as the rail.
I wold never have thought about lofting to mirrored profiles because there is NO way to loft to profiles that are exactly planar with each other....UNLESS you use a rail which solves that planar problem...awesome!
Nick Kloski
