Is there a command to align multiple objects along their geometric centers?
(e.g. think Adobe Illustrator 'align' or 'distribute')
Joe
Hi @Anonymous,
Yes there is, it's called "Align" tool (under the Modify menu). If you could make a screencast with the objects that you want to align, it will be much easier to help you.
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Owner, TESREG.com & Fusion 360 NewbiesPlus
TESREG - Fusion 360 Hardware Benchmark
Facebook | YouTube
I don't know about making a screencast, but I can give you a simple example:
Make a rectangle 40mm x 60mm x2. Lets arbitrarily call one of the 40x60 faces the 'top' surface.
Make a cylinder, place cylinder on top surface of box, exactly on the center of one of the 40x60 faces.
I've played around with 'align', it doesn't seem to do what I need.
Joe
Ben Korez
Facebook | YouTube
