Hello.
Created a 3D sketch.
How do I change 3d sketch dimension?
thank you.
Have a nice day.
I don't think you can add dimensions to a 3d sketch, anything above or below the active sketch plane is selectable with a dimension. One workaround might be to create constitution sketches on different planes and use points on those. Here sketch1 has 2 points constrained with dimensions used in sketch2 to snap end points to.
Mark
Mark Hughes
Owner, Hughes Tooling
Wait. You can't dimension a 3D sketch? I can't even seem to add constraints. Is this a fact?
Yes 3D sketches do NOT yet offer dimenions - that is a fact.
Dimensions best work in 2D sketches while in Alias you can use the length of a line as a somewhat dimension replacement.
But how you do something in Alias is radically different then you use a parametric modeler like Fusion.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
I prefer to make my 3D sketches as intersections of 2D sketches.
I prefer to control my 3D sketches in SolidWorks as intersections of 2D sketches.
You can diamention a 3D sketch when you do it, not after.
