Design Review
Welcome to Autodesk’s Design Review Forums. Share your knowledge, ask questions, and explore popular Design Review topics.
Problems running Design Review 2013
1 REPLY 1
marco.teixeira
873 Views, 1 Reply
Hello.
In several machines, with Windows 10 Pro, and Autocad, Revit 2017 and other products installed, that run as expected, I installed Design Review 2013.
With Design Review, I'm facing several problems in more than one machine. The application does not run and is even impossible to reeinstall/unistall. You
can view the errors in the attachments. It looks there is a problem with some dependecy or missing dll, but i'm afraid that further actions may cause the
other  Autodesk software to fail. What can be done?
1 REPLY 1
pendean
in reply to: marco.teixeira
Try running ADR2013 in Win7 Compatibility Mode, and 'as administrator" to see if it helps.
ADR2013 development stopped in the year 2012 well before all the 2017 versions you note running perfectly on the was-not-there-in-2012 Windows 10 platform.
