I have a DWF. file that contains AutoCad drawings and a png. image, I'm using Autodesk Design Review to convert this DWF. file to PDF and/or to print this file to a paper. The problem is, however, when I open the output PDF file, or printed paper, I see that the png. image is in a low resolution (bad), but the drawings (lines and texts) are fine.
I tried before to convert my drawing using DWG file to PDF.pc3 from the Layout and the output png. image was good (high resolution).
I know you may ask why would you then use DWF to PDF instead of DWG to PDF if it converts the png. image without any issue, well I have a specific font that can only be printed using the DWF to PDF.
Thanks!
To (maybe) solve this post after one year ..
There are two ways to set the resolution (the quality) of raster-output.
- One is the default, found in the "Options"
- One is in the print menu, lower left corner, - "Expnaded settings". There you can set the "colour quality" and the resolution up to 2400 dpi.
