When setting autocad to automatically publish a dwf version to a folder:
If you publish each time you save, only the first version will save to the folder unless you change the file name for each revision. This means either the drafter or the shop floor will have to change the drawing name. For example part1.dwf to part1.1.dwf etc. This could become very confusing after markups and new revisions of the dwf. I am not sure why autodesk didn't just change to part1(1).dwf if there was already a file with the same name.. much like how downloads work in the download folder.
Any way to handle this issue?
JG
