It started about two weeks ago when I go to measure areas or lengths I can not change the color it is stuck on red. The drop down menu's show other colors but when I click on another color it just stays red. I like the option and use it always when measuring different items. Can someone out there help me.
I have been using Design Review for about 4 years now and never had this problem. I have Design Review 2013
I fixed the problem I think. I clicked on measure area then went to the fill color right clicked on the red color. It gave me a menu add to quick access Toolbar. I clicked that and another fill color bar showed up in the top left corner. I was able to change colors from there.
Hi
I have the same problem. I can not change the colour, line size or line type in the formatting tab. Some options are available but most are not.The problem is the same in all files and for all drawings. I have un-installed and re-installed the programme but it has not helped. Can any one help?
