ecotect
ecotect
is there an alternative program to ecotect since it is no longer available?
samuelsanf
There is not anything like Ecotect right now, but Revit has Lighting Analysis for Revit App for sun and interior light analysis
You can use Insight 360 for Building Energy Analysis (I think it is a replacement for Green Building Studio).
http://www.autodesk.com/products/insight-360/overview
Autodesk CFD can be used for Wind Tunnel analysis
http://www.autodesk.com/products/cfd/overview
I never used ecotect completely, so I do not know what other analysis to do. But as I know, there is not another Autodesk Product that can do acoustic analysis,
Here Autodesk Courses that might be of interest to you.
https://sustainabilityworkshop.autodesk.com/bpac
https://sustainabilityworkshop.autodesk.com/simulation-cfd
J. Samuel Santana F.
¿Te resultó útil esta publicación? Dale a Me gusta.
¿Tú pregunta fue respondida correctamente? Haz click en el botón ACEPTAR SOLUCIÓN.
samuelsanf
Take a look here:
https://knowledge.autodesk.com/support/ecotect-analysis/troubleshooting/caas/sfdcarticles/sfdcarticl...
Emmsleys
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
