Digital Signature of DWF file in Autodesk Design Review 2013 - Windows 11 ERROR
Carl_osfer
Observer Observer
Carl_osfer
Observer
Observer
Good afternoon,
I request support regarding the need to use the digital signature of dwfx files, which only occurs in Autodesk Design Review 2013.
I bought a recent computer and it comes with Win11 as a base but it does not allow the installation of Autodesk Design Review 2013. Without this software it is not possible to use the digital signature in a dwf or dwfx file.
Does Autodesk have a solution for this? They were selling this solution to designers and local authorities and now we are left with the processes stuck on a discontinued platform for win11.
Thank you for your best attention.
Boa tarde,
solicito o apoio relativamente a necessidade de utilizar a assinatura digital de ficheiro dwfx que apenas ocorre no Autodesk Design Review 2013.
comprei um computador recente e vem com win11 de base mas não permite a instalação de Autodesk Design Review 2013. sem este software não é possivel utilizar a assinatura digital em ficheiro de dwf ou dwfx.
a Autodesk tem alguma solução para isto? andaram a vender esta solução aos projectistas e autarquias e agora ficamos com os processos presos numa plataforma descontinuada para win11.
Agradeço a vossa melhor atenção.
Carlos PFerreira
pendean
Community Legend
Community Legend
We are all end users just like you @Carl_osfer so asking around here have little value, plus Autodesk has indicated that DesignReview stopped being developed back in the calendar year2018
https://forums.autodesk.com/t5/design-review/is-design-review-discontinued/m-p/8483469#M14477
https://forums.autodesk.com/t5/user/viewprofilepage/user-id/270816
NOTE: ADR2013 was not designed for and has not been officially updated to work in Windows8-10-11
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Autodesk-Design-Re...
Carl_osfer
Observer
Observer
yes its true, but the stupiditty of all, is that theres no alternative tho sign the dwfx without DR2013...
pendean
Community Legend
Community Legend
Considering Autodesk abandoned ADR2013 back in the year 2017 with the release of ADR2018, it might be worth reviewing your commitment to a feature the developer no longer supports.
