I use Autodesk Design Review to measure square yardage for sod on approved site plans. I have run across drawings with a scale of 1" = 15'. This scale is not listed on the drop down menu for measuring. Is there any way to add it?
Just curious, did you mean 1:15, which is a common metric scale, and not 1"=15'? Or did you mean 1"=16', which of course is 1/16"=1'-0" by another name.
And, is there a reason you couldn't just set a Custom Scale, which is the option at the bottom of the scale list in the "2D Units and Scale" dialog box?
Your reply is a little vague, so just checking, to rule out the basics.... if the DWF file was printed at 1" = 15', then the custom scale would be 1 = 180.
(1 inch = 180 inches)
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
