Autodesk,
Autodesk Design Review is a valuable tool for my work. When are you planning to update since the last known version is 2013? I am having trouble using it in Windows10 OS and there are some issues withe DWG True View 2017
I wasn't aware.
However, what happens when you have to work off-line?
From what I just saw, I don't see markup tools for reviewing drawings; correct?
The program selects de "Simple Cases" option.
If I click the OK button a "Value out of limits" warning displays right after.
For the selected member the "Loads" window is empty.
If I run the calculations, a "Calculations Errors" window displays with the following message:
"Code combinations: Simple load cases have not been defined"
