Actually I am facing the same problem, the only solution I found is to make your sheet A0 size (or any large paper size) before exporting it to DWF:
1-Right click on layout name in AutoCAD and select page setup manager.
2-Select modify to the current page setup of your layout.
3-Change paper size to A0 or A1 (you have to select any PDF plotter you have in the list of "Plotter Name")
4-Then press ok and export the layout to DWF.
But I prefer to have an option in (ADR) to control the arc length of revision cloud.
Thanks!
Start the command, "REVCLOUD" then type in 'A' to specify the sub-command, "Arc Length", then specify your new arc length.
Or, if you have tricky, funny looking arcs near the corners of your cloud, you can always manually stretch each arc out by selecting their nodes.
Silvia,
I have with the same problem. Is there's any setting to change the revision cloud? (arc size)
Emman
Am facing same issue, as i know, unfortunately there is no option to modify arc length in DWF (ADR).
Hope AUTODESK will resolve that issue.
due to the arc length being too large in relation to the overall size of the cloud.
I have this same issue. All i do is make a large cloud, then select the object and scale it down to the size I need. Works perfectly and is much faster than individually adjusting arcs. Hope this helps, not sure if anyone is still following this issue or not.
