Design Review - Custom Symbols Lineweight
I am attempting to create symbol libraries for DWF/PDF markup using Design Review. I have a library of symbols to use exported in groups to DWF files. When I open up the DWF files the symbols all appear correct but when I import the symbols only one or two of the group will retain its lineweight.
In the attachment the 5 symbols on the right are the actual DWF, and the 5 on the right in red are the imported stamps. Only 1 of the 5 retains its lineweight. Has anybody seen this before and any ideas for a fix?
For reference I am exporting from the model space retaining block and layer settings and sending to 1/8" scale. I have tried other scales with similar results.
TAgrafas
@Anonymous, I am having the same issues...we export our symbols to a dwf file and then use "Create Catalog from DWF..." in Autodesk Design Review to import the symbols for our users.
I ended up exporting and importing each symbol individually. Then I put them all on a DWF, selected them, and created a library from them. It worked for one set of symbols, not the next. The second set has hatches with transparency. A few are working, a few are not. It seems to be a game of work arounds.
TAgrafas
@Anonymous, do you mind explaining your process more thoroughly?  What did you use to export them individually?  I suppose if I have to complete a few work arounds it will be worth it if it works.  Not one of our symbols currently comes in at the correct line weight but they appear correct in the dwf file that contains all of them.  Thanks!
I'm using AutoCAD 2015LT.
To export individually I zoom in using model space on one of my blocks and choose Export > DWF.
 Under Options I use:
  • Override precision - None
  • Layer information - include
  • Merge control - Lines overwrite
  • Block information - Include
  • Block template file - Local file, create one if you don't have one (click the drop down triangle and click create). I originally used this to pull a name parameter from the block. Not sure it's necessary with the individual export since I can rename all of the blocks.
Back to the save as DWF screen, choose export Display and choose a page setup if your default is not what you want and click Save.
In Design Review open any pdf or dwf file. Navigate to Markup & Measure and click Symbols. Choose Create Catalog from DWF. Choose a file and choose Import each sheet as a symbol. I had to use this method to keep lineweights.
Repeat this process for all symbols. Now go back to your symbols drop down, choose each of your blocks and add them to your drawing. Click and name each under the markup tree.
Finally select your blocks and under Symbols choose Create Catalog from Selection. Name it and you're done. You can delete all of the individual blocks using the Manage Catalogs option.
It's all one giant work around and it only worked for one set of my blocks. I moved to the next set which are a little more complicated and the process utterly failed. Back to the drawing board I guess.
-Andy
TAgrafas
@Anonymous, our blocks for the most part are simple ones so I am hoping this process you posted will work for us, I just have not had a chance to test it yet (our 2018 deployment took priority) but thanks for posting!
Thank You!.... This method worked using AutoCAD 2017 and Design review 2017.
Tho I must add IMPORT EACH SHEET AS A SYMBOL needs to be checked in order for the process to work the way we want it to.
