Autodesk Toxic 2012 / 2014 Crashes on Startup.
Message 1 of 1
Hello.
I have tried unsuccessfully for some time to get Toxic up and running. I had installed the 2012 version that came with my Max subscription and it ran only once past the splash/ boot screen. I had the following crash error on a new install of Windows 7 Pro on a SSD drive that only runs Max, MatchMover, Toxic, Combustion and Sony Vegas. no other software is running on the machine.
Toxic stops at initlizing module libDLofxUi.
Problem signature:
Problem Event Name: BEX64
Application Name: composite.exe
Application Version: 7.0.0.2502
Application Timestamp: 4e30e83d
Fault Module Name: MSVCR90.dll
Fault Module Version: 9.0.30729.4940
Fault Module Timestamp: 4ca2e32e
Exception Offset: 00000000000552c0
Exception Code: c0000417
Exception Data: 0000000000000000
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 3081
Additional Information 1: fa6c
Additional Information 2: fa6c3801e0b3612e5010f6c0adafaf15
Additional Information 3: 0efc
Additional Information 4: 0efccf5053b797f4f3f0de47aea9a21b
I downoaded the 2014 version of Toxic thinking I would get a working version after all. *Epic Fail* it would appear that regardless if you paid for it or AD give it away two years later I am no better off.
Application Version: 9.0.0.57248
Application Timestamp: 5316e056
Locale ID: 3081
Additional Information 1: 5c67
Additional Information 2: 5c673a76feb9196c6de3f835abb740c1
Additional Information 3: 7dbd
Additional Information 4: 7dbdc8cad52389f328a08630126db21c
Any suggestions to kick this Beast in the arse and get it working would be greatly appreciated.
Timberoz
Replies (0)
