insert a svg
insert a svg
insert a svg
Good morning
I create profiles in Adobe Illustrator
export profiles svg
but when importt in Fusion are completely out of scale
How can  import the profiles in scale with fusion
attached a square 10x10 mm
in fusion is 28.347 mm
HughesTooling
Take a look at the 3rd page in this post it explains why the scale is different.
Link
Mark Hughes
Owner, Hughes Tooling
HughesTooling
When you import your SVG under scale enter 0.35277777777778 then OK.
After insert gives.
Mark Hughes
ok this is a good solution for me.
but it would be better that Fusion import with the right scale?
