gray gost bug
gray gost bug
daniel_lyall
Mentor Mentor
Message 1 of 13
gray gost bug
daniel_lyall
here`s a bug for ya whatch the screen cast
http://autode.sk/1KMOzTq
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Replies (12)
Message 2 of 13
James.Youmatz
Autodesk Support
Autodesk Support
Hi @daniel_lyall,
Did this just start occurring after the recent update? I've only ever (personally) seen this once before, but it was because there was a Mac OS update pending. Once that user updated their models came out fine. It appears that you are Windows though, so one thing to check is to make sure everything is up to date, Windows, graphics card, etc. Another possibility to look into may be a clean uninstall. It's possible (assuming this only happened after the update) that the update may have come in funky for you and messed some things up. Cleanly uninstalling may help isolate this problem. The steps for a clean uninstall can be found at the following link:
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-...
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 13
daniel_lyall
no it`s been happing for some time everything is up to date
Daniel Lyall
The Big Boss
Mach3 User
Message 4 of 13
I've had the same problem as well for some time now and I cant seem to figure out what is wrong with it. Please help!!!
Message 5 of 13
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous and @daniel_lyall,
Can the both of you please post your dxdiag files here so that I can take a peek at some things. You can find that file by following these steps:
1. Launch %windir%\system32\dxdiag.exe
2. Select Save All Information
3. Please reply with the resulting *.TXT file attached
4. If you'd prefer not to share it with everyone, you can send it to me at james.youmatz@autodesk.com
James Youmatz
Message 6 of 13
daniel_lyall
done that last time I posted about it nothing came of it
Daniel Lyall
The Big Boss
Mach3 User
Message 7 of 13
Here is the txt. file you wanted.
Message 8 of 13
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
One thing to note is that your graphics card driver is from 2010, my guess is that its due for an update! This may or may not help the issue (entirely possible it will though since this is a graphics related issue). You can download your driver from the following website (please note that the first few downloads within that link are NOT drivers - look at the type. Also make sure to look through the description of the driver to make sure it works for your computer. Unfortunately Intel graphics cards are not always the easiest to download):
https://downloadcenter.intel.com/product/81507/Graphics-Drivers-for-Mobile-Intel-4-Series-Express-Chipset-Family
On the off chance that those don't work, like I said Intel doesn't always make it easy to update their graphics card, you can find the drivers by typing in your computer information in Toshiba website. Once you enter your computer model, make sure to filter the results by Display. The link is below:
http://support.toshiba.com/drivers
Let me know how that goes or if you need any help, as I'd be more than happy to help!
James Youmatz
Message 9 of 13
Which driver do I need though? I am on the toshiba website and I need to know which one.
Thank you for your help.
Message 10 of 13
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Just wanted to let you know I sent you an email so that we can chat about this further. I would like to ideally set up a remote session so that I can see what is going on for myself and talk with you about updating your graphics driver. Once we figure out what the issue is, I will report my findings back here for the rest of the Community!
James Youmatz
Message 11 of 13
Also, I tried fusion 360 on windows to using the same computer, and I got the same problem. If it is my computer or it is outdated I will need help finding another for fusion 360.
Thank you,
RocketRac00n
Message 12 of 13
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
I noticed your post in another thread related to this issue. It seemed for them an update to Fusion helped. Just curious, were you able to update your driver? Also, I never heard back from you from the email I sent regarding a remote session to help you install your driver.
James Youmatz
Message 13 of 13
Yes I did update my driver, but I never got the email.
Also, the driver worked! It now allows me to see the shapes and forms I make thank you!!
