Workflow Demo on 'Data Exchange from Federated Revit Models To PowerBI'
rakesh.borse
Community Manager Community Manager
Message 1 of 28
rakesh.borse
This blog post discussed the workflow of Data Exchanges in the context of linked or federated Revit models, shedding light on existing challenges and offering practical solutions. It further demonstrates, through a detailed demo video, the process of leveraging Data Exchanges in Power BI to craft insightful dashboards.
federated model in Revit is a composite model that integrates multiple discipline-specific models (such as architectural, structural, and MEP models) into a single, cohesive model. This allows for better coordination, clash detection, and overall project management. Each discipline maintains its own model, but they are combined for coordination purposes.
Linked Revit Model
linked model in Revit refers to a Revit file that is referenced within another Revit file. Linking models is a common practice for incorporating external discipline-specific models into a main model without merging them into a single file. Linked models retain their independence but are displayed and coordinated within the host model.
Data Exchange Created from Federated Revit Model
Creating a Data Exchange from a Federated Revit Model (incorporates linked models from various disciplines) is possible using Revit Connector and Autodesk Construction Cloud (ACC). Individual elements from the linked Revit models remain distinct entities within the Data Exchange. If you're using the ACC to upload the Federated Revit Model, please ensure you have all the linked models visible in that Revit file.
Loading in PowerBI Data Connector
Data exchange created from a Federated Revit Model can be successfully loaded into PowerBI using the Autodesk Data Connector. A few key points are:
  • Individual Elements: Elements from the linked Revit models are listed as separate rows in PowerBI.
  • Parameters: Parameters from the linked Revit models are listed as individual columns in PowerBI.
  • Pre-filtering: The "Filter By = category" option works on all the elements from the linked Revit models.
  • Property Selection: The 'Select Properties' drop-down lists all properties from all elements of the linked Revit models.
  • Unique Revit Element Id: Each element from the linked Revit models is identified by a unique Revit Element ID.
Known Limitations
  1. Coloring and cross-highlighting in the Autodesk Data Viewer may not work as expected due to the current implementation. In this implementation, an element from the viewer is represented by two things: the element itself and the RVT Link. This can result in incorrect coloring and highlighting, as the 'RVT Link' overrides the element's properties.
  2. No out-of-the-box property available 'Linked Revit Model' which can help to distinguish elements respective to each Linked Model.
Workaround
  1. To address coloring and Cross-highlighting limitations, follow these steps:
    1. Go to Transform Query Editor.
    2. Remove the rows corresponding to "Revit Category Type Id = RVT Links".
    3. Close and apply the changes.
    4. After performing these steps, coloring, and cross-highlighting should work as expected.
  2. To address the missing property 'Linked Revit Model' limitation, manually create a custom 'Project Parameter' in each of the linked models which can help to distinguish respective elements.
Demo Video
Replies (27)
Message 21 of 28
rakesh.borse
Hello @MohamedElmasri
Mandatory columns are ExternalElementId and sample.viewer (if you are working with viewer).
Message 22 of 28
rakesh.borse
@MohamedElmasri @mahmoud_rawi9JPZQ
If you're on the latest version v2.0.11 and still experiencing this error, we will need temporary access to the exchange  so that we can quickly debug and attempt to resolve the issue.
Message 23 of 28
MohamedElmasri
I select the mentioned columns in Transform, and it's loaded now
on another hand, I see this post about federated models
https://aps.autodesk.com/blog/autodeskr-data-connector-power-bi-now-supports-federated-views
but the current version is 2.0.11 that already I have
is there any updates anywhere ?
Message 24 of 28
rakesh.borse
Hello @MohamedElmasri ,
Yes, the feature mentioned in the post is live; we have updated the v2.0.11 on the 27th of March 2025, which includes support for federated models.
So, I would request to uninstall the earlier v2.0.11 if you had, then install the latest v2.0.11 from the app store - https://apps.autodesk.com/BIM360/en/Detail/Index?id=630329146206435612&appLang=en&os=Win64https://ap...
Do try this new feature and let us know the feedback. Thanks!
Message 25 of 28
jackhack90013
Community Visitor
Community Visitor
Great blog post! The demo video really helped me understand how to use Data Exchanges with Revit and Power BI.
I’m definitely going to try building a similar dashboard—found more tips on the official Power BI website too.
This workflow could really streamline reporting for complex models!
Message 26 of 28
rakesh.borse
Nice to hear that Jack. We have more of such demos at https://www.autodesk.com/learn/ondemand/curated/power-bi-data-connector which can be also be helpful to you.
Rakesh
Message 27 of 28
LucasFMartins_IPS
Expression.Error: The column 'children' of the table wasn't found.
Details:
children
Message 28 of 28
rakesh.borse
Hello @LucasFMartins_IPS ,
Are you still facing the problem with the filter you are trying? Can you please let us know if this is happening only with filter you shared in screenshot or with any other filter? How about loading the exchange without filters? This will help us better narrow down the issue.
Thanks and Best Regards,
Rakesh Borse
