The field 'index' already exists in the record,
Nirav_Panchal6MBSJ
Nirav_Panchal6MBSJ
Is there anyboday who can help to address this query, I  get this when i load the data exchanger in Power BI.
rakesh.borse
Hello Nirav,
This error generally occurs when there are multiple columns/properties with the same name. We have handled this case internally but I suspect a bug in your case. To investigate better, is it possible for you to share the exchange with us?
Also, just to unblock you, a workaround could be not to load the whole exchange but to load using filters. Using filters you can load only the properties you want. You can refer to the documentation here: Loading Data Exchange with Data Filter
Thanks and Best Regards,
Rakesh
Nirav_Panchal6MBSJ
Hi Rakesh. how do I share exchange? its on BIM360 and has 0Bytes which does not allow to download
rakesh.borse
Hello Nirav,
You will need to add me into the BIM360 project and then provide 'Edit' permission to the exchange's parent folder. After that, just share the exchange URL. Please refer to the below:
https://help.autodesk.com/view/BIM360D/ENU/?guid=GUID-DBB775D1-EC66-4178-BC90-CFFD55A1C6A3https://help.autodesk.com/view/BIM360D/ENU/?guid=GUID-DBB775D1-EC66-4178-BC90-CFFD55A1C6A3
https://help.autodesk.com/view/BIM360D/ENU/?guid=GUID-2643FEEF-B48A-45A1-B354-797DAD628C37#add-a-use...
Add the below members:
rakesh.borse@autodesk.com
suraj.kumar1@autodesk.com
ravindra.bhadale@autodesk.com
Observer
Observer
@rakesh.borse any news about it? i'm with the same issue
rakesh.borse
Hello @0133371 ,
This error generally occurs when there are multiple columns/properties with the same name. We have handled this case internally but I suspect a bug in your case. To investigate better, is it possible for you to share the exchange with us? Please write us at data.exchange.support@autodesk.com
Rakesh
Nirav_Panchal6MBSJ
Thanks Rakesh,
I will try this and let you know
