Data Exchange Community
Welcome to the community conversation around interoperability workflows enabled by Autodesk Data Exchange Connectors, SDKs, and APIs. What are Data Exchanges? Instead of sharing a file, share a subset of geometry and properties from your model for use in other apps!
Learn more on our landing page.
autodesk01UXLB7
99 Views, 1 Reply
OAuth Redirect URL Issue
When doing OAuth authentication with Autodesk API, I encountered an issue related to getting the wrong URL during redirect.
After the user logs in and grants access, I expect the redirect URL to return with the code parameter in the redirect URL (e.g. http://localhost:8080/callback?code=<auth_code>).
but I get https://auth.autodesk.com/as/7cXNFTh8yE/resume/as/authorization.ping
I am using Unity and authenticating in native web apps for IOS. However, after testing it seems to work fine with Android. My IOS is stuck with the above error. Although this is not a bug that I cannot get the auth_code from the redirect URL to get the access token?
Labels (1)
1 REPLY 1
lejla.s
in reply to: autodesk01UXLB7
Hi @autodesk01UXLB7 ,
sorry to hear that you are experiencing authentication issues, I'm sure our Autodesk Platform Services experts can help you solve this.
This forum is intended for questions around the Data Exchange Connectors / SDK, but I'm including a link where you can find more information about contacting the APS support concerning other Autodesk APIs. I recommend checking out Stackoverflow first and then contacting the support (both links are included on this page): https://aps.autodesk.com/get-help
Best,
Lejla
Lejla Secerbegovic
Product Manager - Data Exchange
BIM me up! BlogYoutube
