Data Exchange Community
Welcome to the community conversation around interoperability workflows enabled by Autodesk Data Exchange Connectors, SDKs, and APIs. What are Data Exchanges? Instead of sharing a file, share a subset of geometry and properties from your model for use in other apps!
Learn more on our landing page.
Inventor 2025 - NO DATA EXCHANGES AVAILABLE IN THIS PROJECT
3 REPLIES 3
poornam7
448 Views, 3 Replies
HI, IAM TRYING TO CREATE DATA EXCHANGE INSIDE INVENTOR 2025 . I HAVE ACC LICENSE AND NECESSARY PERMISSION . I INSTALLED INV2025 INTEROP TOOLS AND LATEST DATA EXCHANGER. STILL IAM UNABLE TO FIGURE OUT THE ISSUE. ANY HELP
Labels (1)
3 REPLIES 3
rakesh.borse
in reply to: poornam7
Hello @poornam7,
It is evident from your screenshot that you're using the Data Exchange which comes inbuilt with Inventor 2025, which only supports the 'Load' workflow. To get full functionalities of 'Create' and 'Load', you need to install the Inventor Connector 2025 which is currently in Private Beta. Could you please share your email ID so that we can invite you to the Private Beta program?
In the meantime, you can visit out Help Doc - https://help.autodesk.com/view/DATAEXCHANGE/ENU/?guid=inventor_create_update
Thanks and Best Regards,
Rakesh Borse
poornam7
rakesh.borse
Thanks @poornam7.
You've been invited to the "Data Exchange SDK, Connector & API Private Beta" project. You need to sign in and join the beta project. You can download the Inventor Connector 2025 from here
Please check our Public beta Documentation page to get started with the basic functionalities and FAQs of the connector
