Data Exchange Community
Welcome to the community conversation around interoperability workflows enabled by Autodesk Data Exchange Connectors, SDKs, and APIs. What are Data Exchanges? Instead of sharing a file, share a subset of geometry and properties from your model for use in other apps!
Learn more on our landing page.
How to create data exchange in Navisworks or ACC ?
1 REPLY 1
Diego_GonzalezHQTGC
220 Views, 1 Reply
Hello all,
Within what offers the data excahnge is general this bridge file (neutral), and put connect it with Power Bi.
Now, is there any possibility to create the data exchange inside Navisworks or ACC ?, without having to go through the native software, e.g. Revit, or others.
I would appreciate any advice
Thanks.
Diego
Labels (2)
1 REPLY 1
Hello @Diego_GonzalezHQTGC ,
Yes, you can create Data Exchange from the Revit files and IFC Files uploaded/collaborated to the Autodesk Docs/ACC.
Here is the Help Documentation: https://help.autodesk.com/view/DATAEXCHANGE/ENU/?guid=DEX_Prepare_File_Revit_Exchanges
Here are the learning content demos:
  1. https://www.autodesk.com/learn/ondemand/curated/data-exchange-for-revit
  2. https://www.autodesk.com/learn/ondemand/tutorial/create-data-exchanges-in-autodesk-docs
And creating Data Exchange from the Navisworks connector is currently under-developement and soon will be available.
Thanks and Best Regards,
Rakesh Borse
