Data Exchange Community
Welcome to the community conversation around interoperability workflows enabled by Autodesk Data Exchange Connectors, SDKs, and APIs. What are Data Exchanges? Instead of sharing a file, share a subset of geometry and properties from your model for use in other apps!
Learn more on our landing page.
BartDeMaesschalck
755 Views, 3 Replies
GraphQL GetHubs
GraphQL Gethubs does not return all hubs?
I am using the "Data Exchange Model Explorer - BETA"
I have a number of hubs on us and european servers. These hubs are not listed with the gethubs command.
When I use the hubId and add "a." or "b." in the GetHub command returns an error "Failed to get hubid"
Labels (1)
3 REPLIES 3
Hi Bart - I am not sure we have this properly documented... can you try adding this to the header...
Emea data is only accessible when a user provides an additional header region=EMEA or  Region=EMEA
The above is indeed not documented and vewry usefull in older API examples.
But I found the solution by reading the avaiable documentation more attentivly:
I had to add this clientId and not only the id af the integration I created.
OK - glad you got unstuck! FYI we have added better documentation on this one...
https://aps.autodesk.com/en/docs/fdxgraph/v1/reference/graphql_endpoint/
