Data Exchange Community
Welcome to the community conversation around interoperability workflows enabled by Autodesk Data Exchange Connectors, SDKs, and APIs. What are Data Exchanges? Instead of sharing a file, share a subset of geometry and properties from your model for use in other apps!
Learn more on our landing page.
General release of the Autodesk Data Exchange Power BI Connector.
2 REPLIES 2
amruthaLQAWE
136 Views, 2 Replies
I have uninstalled the previously installed BETA version and successfully installed the new generally available version. While publishing the model to powerbi web service, I noticed that it is taking considerable time to view or load the model on the service. Could you please provide any guidance on optimizing this process or suggest solutions to improve load times?
Labels (1)
2 REPLIES 2
Quick answer - try to keep your element count to 30,000 or so - this will make the loading times MUCH faster. Exporting an entire Revit model to a Data Exchange will be slow.
I’m encountering an issue with the Autodesk Data Connector in Power BI. After publishing my report to the Power BI Service, before the data loads, the introductory "steps to configure" text remains visible. This causes the model and visuals to be obscured, especially when any filters are applied—it gets stuck on the instructions screen. Any guidance on how to remove or bypass this introductory text in the published version would be greatly appreciated!
