Data Exchange Community
Welcome to the community conversation around interoperability workflows enabled by Autodesk Data Exchange Connectors, SDKs, and APIs. What are Data Exchanges? Instead of sharing a file, share a subset of geometry and properties from your model for use in other apps!
Learn more on our landing page.
Cannot add 3d Viewer on power bi
14 REPLIES 14
Message 1 of 15
arsanious.abtnagoZG5H9
827 Views, 14 Replies
based on the new release Data exchange connector , i should find something called "Data Source".Viewer when i load the data exchange into Power BI. However, i cannot find it , even if the Data exchanged published on ACC with a 3D viewer. Any thoughts ?
Labels (1)
14 REPLIES 14
Message 2 of 15
Hello @arsanious.abtnagoZG5H9 ,
You need to load the Data Exchange itself using the Get Data > 'Autodesk Data Connector for PowerBI'.
Message 3 of 15
Hello @arsanious.abtnagoZG5H9,
If possible could you please share the .pbix file and also provide access to the Exchange to me rakesh.borse@autodesk.com?
I will try to reproduce the issue at my end.
Message 4 of 15
it is what i have done , However, when i load the data exchange on power bi using get Data then  'Autodesk Data Connector for PowerBI , i can find the data exchange but there is no 3D inside as it has been mentioned in the release notice.
Message 5 of 15
Message 6 of 15
I cannot give you access to the exchange for a security reason protocol , can you please arrange a conference call to show you the issue ?
Message 7 of 15
taking into consideration that iam using Revit 2023 not Revit 2024 and i have a
colleague did the same steps than me but on Revit 2024 and it worked.
Message 8 of 15
Are you available now or in hour or so? Please send me a zoom or teams meeting invite at rakesh.borse@autodesk.com. We can connect.
Message 9 of 15
i will send it to you right now . is it ok for you ?
Message 10 of 15
Yes please, Lets connect.
Message 11 of 15
i have sent you the invitation and waiting for you
Message 12 of 15
Thank you @arsanious.abtnagoZG5H9 for connecting over the call. I'm glad that you are unblocked and able to successfully load the Exhcange and viewer. The root cause for your issue of the latest v2.0.7 connector was not installed for you is the fact that you're not an admin and also with UAC disabled. In future, to avoid these issues, I recommend to enable User Account Control (UAC) for non-administrative users
  • Enter administrator credentials when the system specifically requests them, contact your IT team for assistance.
  • In the Windows search bar, search and select Change User Account Control settings.
  • Move the slider to one of the following levels:
    • Notify me only when apps try to make changes to my computer (default)
    • Always notify
  • Select OK to save your changes
  • Select Yes to confirm the changes.
This will enable to prompt of Admin Credentials while installing.
Do let us know for any suggestions.
Appreciate your patience.
Thanks and Best Regards,
Rakesh Borse
Message 13 of 15
Thanks Rakesh for your support
Message 14 of 15
jetbim.user2
in reply to: rakesh.borse
hello sir can u help to connect my bim360 data to power bi by the extention connect data for power bi cuz i had an error to exploit the data and particulary i want to get the 3d views that i have in bim360 just to know my files are in revit 2021
Message 15 of 15
Hi Quick answer jetbim - not sure you can proceed the way you describe...
  • you need a Revit 2023 or more recent file - Revit 2021 is not supported
  • you need to create a data exchange and put it into BIM360 - this is only possible with the Revit connector
  • then you should be able to load that data and 3D viewer into Power BI (Rakesh likely tested this scenario!)
Here is a link to the Revit connectors
2023 - https://apps.autodesk.com/RVT/en/Detail/Index?id=2858772313778376277&appLang=en&os=Win64
2024 - https://apps.autodesk.com/RVT/en/Detail/Index?id=827207946618909505&appLang=en&os=Web
