Thank you @arsanious.abtnagoZG5H9 for connecting over the call. I'm glad that you are unblocked and able to successfully load the Exhcange and viewer. The root cause for your issue of the latest v2.0.7 connector was not installed for you is the fact that you're not an admin and also with UAC disabled. In future, to avoid these issues, I recommend to enable User Account Control (UAC) for non-administrative users
- Enter administrator credentials when the system specifically requests them, contact your IT team for assistance.
- In the Windows search bar, search and select Change User Account Control settings.
- Move the slider to one of the following levels:
- Notify me only when apps try to make changes to my computer (default)
- Always notify
- Select OK to save your changes
- Select Yes to confirm the changes.
This will enable to prompt of Admin Credentials while installing.
Do let us know for any suggestions.
Appreciate your patience.
Thanks and Best Regards,
Rakesh Borse
