Data Exchange Community
Welcome to the community conversation around interoperability workflows enabled by Autodesk Data Exchange Connectors, SDKs, and APIs. What are Data Exchanges? Instead of sharing a file, share a subset of geometry and properties from your model for use in other apps!
Learn more on our landing page.
Automating Geometry Sub-Category Assignment in Revit Using Rhino Layer Names and Data Exchange
1 REPLY 1
Verma7UKV3
41 Views, 1 Reply
We're trying to use the layer name in rhino to assign the geometry to a model sub-category in Revit. That way, the geometry coming in through Data exchange will have a material applied to it in Revit that it gets from the material assigned to its model sub category. Any suggestions on how to do this? Or is it even a possibility?
We tried messing around with the Revit_Category_And_Layer.csv to add the sub categories but it does not work with subcategories.
Labels (2)
1 REPLY 1
rakesh.borse
in reply to: Verma7UKV3
Hello Avinash,
Sub-category mapping is not supported yet. It is only Layer to main category at the moment. We can add a feature request to the support sub-category.
Can you explain more about how the input of the sub-category you envision in the .csv file?
Thanks and Best Regards,
Rakesh Borse
