aps-iot-extensions-demo-master
Guofeng_Qiang21
Observer Observer
Guofeng_Qiang21
Observer
Observer
When I cloned the Autodesk Data Visulization service, aps-iot-extensions-demo-master; I found that "the file extension loaded into the viewer is not supported, try a different file". I replaced `APS_CLIENT_ID`, APS_CLIENT_SECRET,
`APS_MODEL_URN` and `APS_MODEL_VIEW`; the URN and GUID are obtained through a Model Derivative API, following the step:"Translate a Revit File, Generating Room and Space Information". After translating the uploaded .rvt file in OSS into .svf file. I can also visualize it through "Enter the Source File URN on an existing HTML page
We have created". Do I need to add some derivative codes APS.Deriv.cs or .js file to the project for translating? Another issue is the URN and GUID, URN is 64encode of the source .rvt file, there are many GUID in the translation output, can be seen in the attachment, which one is right? I chose the metada named "3D" , instead of "New construction" at the end of the "Translation output" attachment. Could anyone tell me what's the matter? Thank you very much.
Tobias_Hathorn
Hello @Guofeng_Qiang21 - I'm reaching back to the experts on this topic for you. It's a little bit off topic for the thread we're having here around the Data Exchange APIs and SDKs and Connectors - so you may want to consider posting on Stack Overflow as well?
Guofeng_Qiang21
Observer
Observer
Many thanks for your suggestion. I use the community for the first time. I will consider the stack overflow as well. Then, should I copy the question to the stack overflow?
Tobias_Hathorn
yes, I think that copying your question over there would be best - you'll get an answer from the experts on that API!
