Data Exchange Community
Welcome to the community conversation around interoperability workflows enabled by Autodesk Data Exchange Connectors, SDKs, and APIs. What are Data Exchanges? Instead of sharing a file, share a subset of geometry and properties from your model for use in other apps!
Learn more on our landing page.
3D VIEWER DISSAPEARING AFTER OPENING POWER BI FILE AGAIN
2 REPLIES 2
Argelia_Barcena
193 Views, 2 Replies
I have been encountering this issue where the 3D Viewer just goes missing and I cannot seem to reload it. I need to recreate the visual each time. What is causing that?
Examples:
  • I re-opened the file this morning and it was gone
  • When I undo a command in a chart (not the viewer part) it unloads the 3D viewer
I do have the latest Data Exchange and Data Connector installed.
ARGELIA BARCENA
Labels (1)
2 REPLIES 2
Hello @Argelia_Barcena,
Yes, it happens where there are filters applied in the charts.
After opening a saved ".pbix" file, make sure to remove all applied filters to view the model in the viewer.
It is a known limitation on our side currently.
Thanks and Best Regards,
Rakesh Borse
Same here
Frustrating
