Slider Controls on C360
I am building a configurator for a client and it contains sliders as controls on the forms. When I upload the model to C360, the sliders are stripped out. Are sliders not supported on C360?
D0UGLAS
Probably this
Configurator 360 does not allow the following in iLogic rules: MessageBox, MsgBox, InputBox, GoExcel, COM Excel functions
https://knowledge.autodesk.com/support/configurator-360/learn-explore/caas/CloudHelp/cloudhelp/ENU/C...
I'm talking about Slider controls on iLogic forms.
D0UGLAS
Yes, that's what I understood.
Configurator 360 does not allow the following in iLogic rules: InputBox
I believe ilogic forms are a form of ilogic, hopefully someone will correct me if i am wrong.
Sliders are a form of InputBox - therefore unsupported.
I hope this helps.
Jon.Balgley
As you have discovered, sliders on forms are not supported on C360 at this time.
You can use the "embedding" API to create your own UI that contains sliders.  See 360trailers.com (demo site).
Changes to parameters on C360 are not instantaneous.  You won't be happy with the performance if you send new values on every mouse-move.
Jon Balgley
Thanks Jon!
