Recently Finished Project
tolgay.hickiran
tolgay.hickiran
We were working on C360 for a long while now and recently finished another project which has lots of functions. You can check the video!
Some worthwhile ideas
Copy Design should rename ilogic Rules too!
Why Nastran In-CAD doesn't have an SDK?IMPLEMENTED!
Tolgay Hickiran
Founding Partner
SignatureSignature
website
emailskypelinkedinyoutubeemail
Replies (8)
PEMDz
Wish I was good enough to be able to get half way to this 😞 Sadly I'm self taught and there doesn't seem much in the way of instruction out there to be able to do this
clutsa
@tolgay.hickiran When I wrap my project up in the next couple of months I would love to record a similar video. What software did you use to record and edit that?
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
tolgay.hickiran
Its Camtasia
Tolgay Hickiran
Founding Partner
SignatureSignature
website
Paul1084
Hi Tolgay,
Nice Configurator
Are the textures Decals? or Materials? if they are Decals, how are they swapped? do you have all the textures saved in the part, and then suppress unsuppress the relevant Decal? I am trying to do a similar thing, although I am finding keeping all the textures in the part multiplies my file sizes... I was hoping there might be a way to swap the sketch image out based on the image file name.
KKizildemir
Hi @Paul1084 ,
I defined seperate appearances for each textures and colours. The code can sense all the appearances in the 'Document Appearances' and add the names of the appearances to an arraylist. Then we use this arraylist to change the appearance of the part.
There were some key points while I was working on appearances with textures:
  1. I found seamless textures to tile. Seamless textures enables infinite surface tiling.
  2. I increased the contrast of the seamless texture. So it became black&white.
  3. I used these textures within 'Relief Pattern' property to obtain relief lines instead of using a simple texture tiling with different colours. So, I was able to generate each relief pattern for all colours by simply changing the colour of the appearance.2.JPG
I hope this makes sense. Don't hesitate to ask any question.
Signature
website
Paul1084
I have successfully got my model working with a custom Appearance, but instead of relief pattern, I have used a bump pattern. I have also used some code to control the colour by three parameters (R,G,B) so there only needs to be 1 appearance in the part file, and the user can control the colour using an RGB code... this works great in C360 😁:
        Dim OTG As TransientObjects = ThisServer.TransientObjects
		Dim Doc As PartDocument
		Doc = ThisDoc.Document
		Dim feat As PartFeature = Doc.ComponentDefinition.Features.Item("Extrusion1")
        Dim docAssets As Assets = Doc.Assets
        Dim App As Asset = docAssets.Item("Default")
        Dim color As ColorAssetValue = App.Item("generic_diffuse")
        color.Value = OTG.CreateColor(R, G, B)
		feat.Appearance = App
KKizildemir
Hey @Paul1084 ,
That's one of the best ways to change colour, great!
Kind regards,
Signature
website
