C360 slow espacially when pushing parameters from excel
HermJan.Otterman
Advisor Advisor
HermJan.Otterman
My model in Inventor 2017 takes about 20 seconds to update
in C360 through the "interface" it takes a minute.
but when I push parameters and properties collected from excel through a string to the same C360 model it takes 2 minutes or more.
why is the model in C360 slower than in Inventor? on the c360 server is Inventor running, so should it not be the same time?
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
AlexKorzun
Could you please email details of your model to [email protected]:
1. URL, similar to https://configurator360.autodesk.com/1234567890/qazwsxedc
2. Any steps (parameter changes) to demonstrate the problem?
Thank you,
Alex Korzun
Inventor-Revit Interop / Inventor-Fusion Interop / Inventor ETO
Autodesk, Inc.
HermJan.Otterman
thank you Alex,
I send you a mail with some details.
Herm Jan
