Hey everyone,
i cannot for the life of me figure out why i always get an error message when i try to post a drilling operation with the uccnc post processor.
I just drew a quick test part that i'm going to attach to demonstrate my problem.
Everything else can be posted fine but drilling always leads to an Error:
Information: Configuration: Generic UCCNC Information: Vendor: UCCNC Information: Posting intermediate data to 'C:\Users\patri\AppData\Local\Fusion 360 CAM\nc\1001.nc' Information: Total number of warnings: 1 Error: Failed to post process. See below for details. ... Loading locale from 'C:\Users\patri\AppData\Local\Autodesk\webdeploy\production\8230b364be98230257f730ec9822611826c56dfb\Applications\CAM360\Data\Translations\german_de.xml' Code page changed to '1252 (ANSI - Lateinisch I)' Start time: Sunday, September 11, 2016 9:12:56 PM Code page changed to '20127 (US-ASCII)' Post processor engine: 4.2.1 41078 Configuration path: C:\Users\patri\AppData\Local\Autodesk\Autodesk Fusion 360\EK35LDJYQJMS\CAMPosts\uccnc.cps Include paths: C:\Users\patri\AppData\Local\Autodesk\Autodesk Fusion 360\EK35LDJYQJMS\CAMPosts Configuration modification date: Sunday, September 11, 2016 9:04:04 PM Output path: C:\Users\patri\AppData\Local\Fusion 360 CAM\nc\1001.nc Checksum of intermediate NC data: 7e0e8c981718228ba7946d3d4f1f66c6 Checksum of configuration: ec9ca72bbbee908b406bfff0bde002e9 Vendor url: http://www.cncdrive.com/ Legal: Copyright (C) 2012-2016 by Autodesk, Inc. Generated by: Fusion 360 CAM 2.0.2377 ... Warnung: Work offset has not been specified. Using G54 as WCS. Fehler(C:\Users\patri\AppData\Local\Autodesk\Autodesk Fusion 360\EK35LDJYQJMS\CAMPosts\uccnc.cps:566): ReferenceError: spatialFormat is not defined ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Stack dump: getCommonCycle(0,0,-15,5)@C:\Users\patri\AppData\Local\Autodesk\Autodesk Fusion 360\EK35LDJYQJMS\CAMPosts\uccnc.cps:565 onCyclePoint(0,0,-15)@C:\Users\patri\AppData\Local\Autodesk\Autodesk Fusion 360\EK35LDJYQJMS\CAMPosts\uccnc.cps:619 Failed while processing onCycle() for record 319. Fehler: Failed to execute configuration. Stop time: Sunday, September 11, 2016 9:12:56 PM Post processing failed.
Weirdly i can post drilling operations with all the other postprocessors i tried so far but with the generic uccnc and stepcraft post i always end up with an error.
I'm out of ideas what is causing the problem. Even the error message saying that the work offset has not been specified doesnt really make sense because i get the same error message trying to use other offsets.
Did anyone have this problem before and might help me out?
regards
