Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
reducing lines generated by post processor
4 REPLIES 4
camcompco
1001 Views, 4 Replies
Hi there folks, this is my first post . . .and of course, it starts wth me being the student rather than the teacher 🙂
I am using a CNC mill that has a limit of N#### being <= 9999  where the #### is what is limited (N####), I believe I can have more lines.   I also believe there is no need for N line numbers when there is no change in either G-code commands or M-code commands.  I am wondering if anyone knows how to suppress the N numbers when all that is happening is x, y and z are changing directions under one G command (usually G1)
I am hoping that there is a "built-in" way to do this rather than resorting to coding up a process to accomplish this outside of F360
Also, if I list the x,y & z-movements (for example), do I have to separate them with a  ; and place them on their own line (without the traditional N### in front
I hope I am being clear here. . .happy to expand this request with examples if not
Thanks to all that assist.
All the best
Camcompco
4 REPLIES 4
LibertyMachine
in reply to: camcompco
The "built-in" method is an "across-the-board" toggle of N numbers. They are either on or off.
All the best
Camcompco
Not certain what you mean here. Are you talking about manually adding additional movement to the code after you process the job through F360? If so, no, you do not need to put the ;
G01 X1.Y1.F50.
G00 X5.
G1Y2.5F10
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
HybridMachinist
Also dont forget to use smoothing for less code as well.
Love U.S. Mfg.
Thomas Koelndorfer
6514708291
loveusmfg@gmail.com
camcompco
in reply to: HybridMachinist
Thanks for that suggestion, but, what exactly is smoothing and how do I turn it on?  I am relatively new to cam, I have mostly been using conversational Fanuc 21i
thanks again
John
Steinwerks
There is a checkbox in the Passes tab of just about every toolpath.
There is a very good thread about it here: https://forums.autodesk.com/t5/computer-aided-machining-cam/understanding-smoothing/td-p/6636189
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
