hi i am new to this i hope someone can help i created a part with cad programmed with cam machined the part then i wanted to make a few adjustments but when i try to post again i keep getting this no matter what processor i try
thank you
Information: Configuration: Generic FANUC with subprograms
Information: Vendor: Fanuc
Information: Posting intermediate data to 'E:\harroun\10011.nc'
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Thursday, March 23, 2017 10:30:33 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 41304
Configuration path: C:\Users\Owner\AppData\Local\Autodesk\webdeploy\production\f9042f554b0a0c3d14c46a7d9f3679baf42fdd2d\Applications\CAM360\Data\Posts\fanuc with subprograms.cps
Include paths: C:\Users\Owner\AppData\Local\Autodesk\webdeploy\production\f9042f554b0a0c3d14c46a7d9f3679baf42fdd2d\Applications\CAM360\Data\Posts
Configuration modification date: Wednesday, February 08, 2017 1:20:56 AM
Output path: E:\harroun\10011.nc
Checksum of intermediate NC data: b61cfcb4318904f2b7606012595d44bc
Checksum of configuration: 4c97c167c17539376fd65c84fd42c065
Vendor url: http://www.fanuc.com
Legal: Copyright (C) 2012-2016 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.2865
Warning: Work offset has not been specified. Using G54 as WCS.
Error: The depth is invalid.
Error: Failed to execute configuration.
Stop time: Thursday, March 23, 2017 10:30:34 PM
Post processing failed.
Dollars to donuts you have a Clearance Height set lower than a Retract, Top or Bottom Height in (most likely) a Drill operation.
If you're not sure or can't find it, please export a .F3D file (<-- link) and attach it to your next post here.
