Hello.
Anyone can help with the correct PP or setup of a correct PP for the combination:
Woodwop 7.0 and Weeke Venture 115 5axsis machine
I guess Fusion and HSM post can be used??
I found one post on the web - but it only creates 3 axis code - not possible to make indexing.
Thanks in advance
can you post it on here
Did you ever figure out how to do this? is there a post processor out there for Fusion 360 to woodwop 7?
Hi,i also program a Weeke 5-axis machine. I’m very interested in a pp for woodwop7... we could keep each other posted?
Hi @neufeld-j96, @hans.ivar.larsen & @pietbaccaert,
In the link below you find all availible Post Processors of Autodesk.
There is a Woodwop post that can be used as base and can be modifield.
You can do it yourself or contact your local reseller.
In the link below you find near us a list of resellers.
HSM post adjustments needed? Find your right contact here.
If my post answers your question Please use .Accept as Solution & Kudos This helps everyone find answers more quickly!
