Fusion Manufacture
Plunge feedrate error?
21 REPLIES 21
Message 1 of 22
LibertyMachine
1521 Views, 21 Replies
I've got a lot on my mind at the moment, so maybe that's the cause of the issue....
Plunge feedrate is set to 100 ipm. Cutting feedrate is set to 30.
Code output is plunging down at 30 ipm.
This is using my post AND the generic Fanuc. I've looked at my settings and I'm not finding anything that would cause this
Same f3d from MY OTHER POST
EDIT; Anyone else lose all their operation default setting at the last update?
EDIT # 2, this only appears to happen on the "Roughing passes, Stock Contours" tool path. Regular 2D Contours are working as expected. This also happens on a 2D Pocket that I'm using for the counterbores (gives me a spiral toolpath). Entrance is set to Predrill, and it's feeding down at my cutting feedrate
EDIT: Also happening on a Facing pass
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
21 REPLIES 21
Message 2 of 22
I'm running this code through several different posts, just to make sure it's not running into an edit I've done (to the post) that is causing it. Same results across the board
Seth Madore
Message 3 of 22
Steinwerks
in reply to: LibertyMachine
This is definitely a little weird. Used my work post and got the same issue with plunge set to 100 using your file. But the dumper seems to be just fine:
129: onParameter('operation:tool_feedCutting', 30)
131: onParameter('operation:tool_feedPerTooth', 0.001636661211129296)
133: onParameter('operation:tool_feedEntry', 30)
135: onParameter('operation:tool_feedExit', 30)
137: onParameter('operation:tool_feedRamp', 91.99999999999999)
139: onParameter('operation:tool_feedPlunge', 100)
However if you make it a simple no-roughing-passes toolpath you see this (red plunge line):
Which means that the entry on your original part is using the lead-in feedrate for the plunge which is also verified by the dump post (no /*plunge*/ note anywhere):
407: onRapid(5.265991931825172, 1.4139013215312808, 0.5999999909889041)
408: onRapid(5.265991931825172, 1.4139013215312808, 0.19999999699630136)
409: onMovement(MOVEMENT_LEAD_IN /*lead in*/)
409: onLinear(5.265991931825172, 1.4139013215312808, 0.03937007874015748, 30)
410: onLinear(5.265991931825172, 1.4139013215312808, -1.236102336973656, 30)
411: onLinear(5.266721830593319, 1.4115716528704785, -1.236102336973656, 30)
412: onMovement(MOVEMENT_CUTTING /*cutting*/)
412: onCircular(true, 4.500000120147945, 1.171259842519685, -1.236102336973656, 5.303499717412032, 1.171259842519685, -1.236102336973656, 30)
  sweep: 17.402435deg
  radius: 0.8035
413: onLinear(5.303499717412032, -1.171259842519685, -1.236102336973656, 30)
414: onCircular(true, 4.500000120147945, -1.171259842519685, -1.236102336973656, 5.266880425881213, -1.411065229280727, -1.236102336973656, 30)
  sweep: 17.364594deg
  radius: 0.8035
415: onMovement(MOVEMENT_LEAD_OUT /*lead out*/)
415: onCircular(false, 5.314601387564592, -1.4259879044660433, -1.236102336973656, 5.299679012749139, -1.4737091665192852, -1.236102336973656, 30)
  sweep: 90.000431deg
  radius: 0.05
416: onLinear(5.347400575172244, -1.4886316915196696, -1.236102336973656, 30)
417: onMovement(MOVEMENT_RAPID /*rapid*/)
Simple 2D Contour dump:
407: onRapid(4.453716728630967, -1.5837598785640685, 0.5999999909889041)
408: onRapid(4.453716728630967, -1.5837598785640685, 0.19999999699630136)
409: onLinear(4.453716728630967, -1.5837598785640685, 0.03937007874015748, 30)
410: onMovement(MOVEMENT_PLUNGE /*plunge*/)
410: onLinear(4.453716728630967, -1.5837598785640685, -1.18610239404393, 100)
411: onMovement(MOVEMENT_LEAD_IN /*lead in*/)
411: onLinear(4.453716728630967, -1.5337598605418767, -1.18610239404393, 30)
412: onCircular(false, 4.4037165604238435, -1.5337598605418767, -1.18610239404393, 4.4037165604238435, -1.483759842519685, -1.18610239404393, 30)
  sweep: 90deg
  radius: 0.05
413: onMovement(14 /*finish cut*/)
413: onLinear(-4.500000120147945, -1.483759842519685, -1.18610239404393, 30)
414: onCircular(true, -4.500000120147945, -1.171259842519685, -1.18610239404393, -4.812500120147945, -1.171259842519685, -1.18610239404393, 30)
  sweep: 90deg
  radius: 0.3125
415: onLinear(-4.812500120147945, 1.171259842519685, -1.18610239404393, 30)
416: onCircular(true, -4.500000120147945, 1.171259842519685, -1.18610239404393, -4.500000120147945, 1.483759842519685, -1.18610239404393, 30)
  sweep: 90deg
  radius: 0.3125
417: onLinear(4.500000120147945, 1.483759842519685, -1.18610239404393, 30)
418: onCircular(true, 4.500000120147945, 1.171259842519685, -1.18610239404393, 4.812500120147945, 1.171259842519685, -1.18610239404393, 30)
  sweep: 90deg
  radius: 0.3125
419: onLinear(4.812500120147945, -1.171259842519685, -1.18610239404393, 30)
420: onCircular(true, 4.500000120147945, -1.171259842519685, -1.18610239404393, 4.500000120147945, -1.483759842519685, -1.18610239404393, 30)
  sweep: 90deg
  radius: 0.3125
421: onLinear(4.4037165604238435, -1.483759842519685, -1.18610239404393, 30)
422: onMovement(MOVEMENT_LEAD_OUT /*lead out*/)
422: onCircular(false, 4.4037165604238435, -1.5337598605418767, -1.18610239404393, 4.353716692586583, -1.5337598605418767, -1.18610239404393, 30)
  sweep: 90deg
  radius: 0.05
423: onLinear(4.353716692586583, -1.5837598785640685, -1.18610239404393, 30)
424: onMovement(MOVEMENT_RAPID /*rapid*/)
424: onRapid(4.353716692586583, -1.5837598785640685, 0.5999999909889041)
425: onSectionEnd()
Basically I think the feed plunge output bug is directly connected to the previous bug and I would be surprised if it isn't cleared up by the latter when the next update goes through.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 4 of 22
LibertyMachine
in reply to: Steinwerks
Except the feedrate issue also shows up in the Face operation. And the other issue (lead-in, roughing passes) might not be getting fixed in the next update.
IF they have human beta testers, they may need to revise their methods and do a more thorough job
EDIT: It also exists in a pocket routine
Seth Madore
Message 5 of 22
Steinwerks
So it's even easier to diagnose than going through the dumper, the color-coded toolpaths show it as well as the Show Toolpath option. Anyway I'm getting the same results in Inventor HSM.
I would suspect it may not be a toolpath-specific issue, but how the CAM is handling the feedrate application. If this doesn't get a response this weekend I will check HSMWorks on Monday but I don't recall running into this issue.
Neal Stein
Find me on:
Message 6 of 22
Steinwerks
@al.whatmough I think this is heavily related to Seth's other thread on the lead issues as it's obviously not applying feedrates properly, but perhaps this has to do with trimming the leads and the system defaults to specifying the plunge move as a lead instead? Definitely odd things going on and I got the same results trying it in Inventor HSM Pro Build 4.1.0.075
Neal Stein
Find me on:
Message 7 of 22
Hi @LibertyMachine@Steinwerks,
Thanks for posting! This is a known issue logged as CAM-2511 with our development team. I have made a note linking this post to their page on this issue and will circle back here once I receive an update.
We appreciate you bringing this to our attention!
Paul Clauss
Product Support Specialist
Message 8 of 22
Hi @LibertyMachine
Just received an update on this issue from development and wanted to let you know that it should be resolved in the upcoming March update to Fusion! Please let me know if you continue to have issues after then.
Thanks again for bringing this to our attention!
Paul Clauss
Message 9 of 22
That is great news! Thanks for the update
Seth Madore
Message 10 of 22
@paul.clauss did this actually make it into the update? Running through a bunch of scenarios, it appears that it did NOT make it
Seth Madore
Message 11 of 22
Hi @LibertyMachine,
This one is marked as resolved in our log - can you give a specific example of a time when it is not working? Thanks!
Paul Clauss
Message 12 of 22
Umm...yeah. Screencast incoming
Do disregard the last section with the Pocket routine. Leaving Entry set to Helix produces Lead-In feed moves (in the Z) but switching to Plunge cures that
Seth Madore
Message 13 of 22
And Facing operations still plunge with the Lead-In feedrate:
Yellow is rapid, Red is Plunge feedrate, Green is Lead-In/Out, Blue is cutting
Seth Madore
Message 14 of 22
cj.abraham
The original ticket was make to correct the feedrate for pre-drill function. Originally the pre-drill entry method was incorrectly using the cutting feedrate instead of the proper plunge feedrate, even thought the preview was showing a red line for the plunge move.
These are separate cases that I will make new tickets for.
Message 15 of 22
fonsecr
in reply to: cj.abraham
@LibertyMachine,
Can you check that you haven't set a too high Feed Plane? If not desired then simply disable it on the heights tab.
René Fonseca
Software Architect
Message 16 of 22
LibertyMachine
in reply to: fonsecr
@fonsecr
2D Contour with chamfer tool selected (and chamfer option turned on), doesn't care about the "disabled". Still outputs lead-in feedrate for it's Z move. And yes, there are times to use the 2D Contour over the other Chamfer operation
Seth Madore
Message 17 of 22
Default stuff has been messed up for a while, not just the last update.  It seems to randomly grab new defaults for random items.
In 2d contours, it seems the finish Feedrate is used instead of Cutting feedrate in certain cases when Multiple finishing passes isn't even used.
Message 18 of 22
fonsecr
@LibertyMachine,
Ah, my comment was about your last reply for the Face operation 🙂 Need to check if chamfering has any special cases.
René Fonseca
Software Architect
Message 19 of 22
fonsecr
in reply to: friesendrywall
@friesendrywall,
We haven't really changed the defaults behavior. But if you do have suggestions for particular defaults that you think should be different you can always open a topic for that on the idea station so we can have a look.
Please note that if you have overridden the global defaults then you wouldn't see the built-in defaults.
René Fonseca
Software Architect
Message 20 of 22
LibertyMachine
@fonsecr Gotcha. Yes, that was a setting I was missing. Setting it to Disabled goes allow it to use the Plunge feedrate, this is great!
And, I think I've figured out what is going wrong with the 2D Contour w/chamfer option: Safe Distance, on the Linking tab. If Feed Height is set to any option (other than disabled) and it has a value that is unequal to the Safe Distance, there is a movement of "lead-in" feedrate. At least that's what I'm finding. I'll have to make a mental note and run it through various selection options and see if it still holds true
Seth Madore
