I am trying to cut the rectangle geometrical shape on plywood of 1/4 inch thickness. I am trying to create the operation so that the 1/4" thickness is cut in 3 or more steps. Please let me know how to achieve this.
Thanks.
Solved by xander.luciano. Go to Solution.
Hello!
Use a 2D contour and enable multiple depths
Then just put .25 / 3 to do 3 equal step downs. You could change 3 to any number you want.
Let me know if you have any other questions!
Best,
Xander Luciano
